Hello everyone first thing i would like to say is that this was my first time modding, I have built other systems but never done any modding
My system Specs are,
Case: Coolermaster CM-690 Advanced II with window panel
Motherboard: Asus M5A99X EVO Rev 2.0
Cpu / Processor: AMD X4 965 BE C3, Overclocked to 4.01GHz
Ram: 16GB Corsair Vengeance Blue 1600 MHz
Graphics card: MSI GTX570 Twin Frozr III Power Edition OC
PSU: Corsair TX750
SSD / HDD's: Two Corsair Force 3 120GB SSD's and one 500GB HDD
Cpu cooler: Corsair H60i
My computer before i rebuilt and did some modding
So what are my plans? My plans are to rebuild my pc and redo all all my management make it look a lot more cleaner, Carbon wrap the internals of my case, get some custom sleeved extensions, led strips and a psu cover
So the first thing i bought was a custom made molex to 3 sata power i could not find one anywhere that was the right size or length that i needed so i bought one from http://www.icemodz.com/ Between each connector is 6cm's wich is perfect for the way my drives will be mounted,
I also got my psu cover carbon wrap and led strips in the post,
With the led strips i get some zip-ties and sticky pads to help with cable management
So let's get this build going! I started disassembling my PC
I did some modding to the front panel and i removed the cooler master badge
And i also did the same mod to the roof panel
I started to carbon wrapping the internals of my case
I Installed the fans onto the psu cover and I also carbon wrapped the back of the fans too
Testing fitting the psu cover in the case
Testing the led strips to make sure they work and see how bright they are
Put my pc all back together! Look's so much better now! I just need some sleeved extensions
All up and running again! Look's so beautiful
Just some other pictures i took after i got it all up and running again
I took a picture of how the psu cover is being supported but it isn't a very good picture, I made some brackets from 1.2MM Thick aluminium in a L shape to help hold up the psu cover
And that's my build! Please tell me what you think and how it looks, Any questions please comment or send me a pm, When i get some sleeved extensions and more stuff i will post an update to the build log, I also plan to make a custom window panel for the case, And i am also possibly going to be making some hardware change's but not so sure yet
PSU: Corsair TX750
