Coolermaster CM-690-II Advanced Dominator Case Questions
You would need to power via molex from the PSU or a fan controller (which is in turn powered via molex from PSU).
A fan controller is better for the added functionality.
I would daisy chain fans sitting together and use a fan controller.
I have 8 in my mk1 dominator, and this option works well.
Rear on the mobo, all of the other case fans on the fan controller including a push pull on the Thermalright 120a (daisy chain)
I use a 6 channel zalman and i like it, good for around £25.
You need to a good gob on the cable management so some fan extention cables help.
