- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys,
We have received delivery of our the new Nvidia Edition CM-690 II Advanced Dominator Case, these will give any system a look of stlye of sophistication.
Coolermaster CM-690 II Nvidia Edition Advanced Dominator Case - Black/Green @ £89.99 inc VAT
The wildly popular and top-selling CM 690 II Advanced now comes in a NVIDIA Certified Edition. It has been stylized with a NVIDIA themed side panel, badging, and clean looking external and internal accents. This spacious mid-tower has room for up to 3 graphics cards, high-end CPU coolers, top or bottom mount liquid cooling radiators and a 1.8”/2.5” drive adapter. It also features a much improved airflow with oversized mesh and plenty of space for up to 9 fans. Maintenance is a breeze with tool-free drive bays, elegantly simple cable management, and a large CPU cooler retention hole.
- Oversized front and top mesh design for superb ventilation
- Accommodates 120 x 240 mm radiator inside the top or bottom
- Dust-control filters for all meshed areas
- Air cooling support for up to 7 fans
- External SATA X-dock
- Front Green LED fan on/off switch
- Rear retaining holes for water cooling kit
- Includes 1.8" & 2.5" HDD and SSD adapter
- Cable managment and CPU retaining hole for easy maintainence
- Includes VGA card bracket (supports triple GPU card)
- Dimension (W / H / D): 214.5 x 511.8 x 528.8 mm
- Front Cooling: 140 x 25 mm Blue LED fan x 1 / 1200 RPM / 19 dBA
- Rear Cooling: 120 mm fan x 1 / 1200 RPM / 17 dBA
- Top Cooling: 140 x 25 mm fan x 1 / 1200 RPM / 19 dBA (supports 120 / 140 mm fan x 2)
- Bottom Cooling: 120 mm fan x 2 (optional)
- HDD cage Cooling: 120 mm fan x 1 (optional)
- VGA holder Cooling: 80 x 15 mm fan x 1 (optional)
- 4 x 5.2" Drive Bays
- 6 x 3.5" Drive Bays
- 2 x 2.5" Drive Bays
- I/O Ports: USB2.0 x 2 / eSATA x 1 / Audio
- Expansion Slots: 8
- 2 Year warranty
Only £89.99 inc VAT.
ORDER NOW
We also have a range of green case accessories to compliment this case.
Akasa AK-274CG-4GNS 120mm Green LED Fan @ £10.99 inc VAT
his is an ultra quiet 12cm case fan delivering high air volumes with an incredible acoustic performance of only 17.5dB(A). The bright Green illumination is achieved by four hi-bright green LED complemented with a crystal green frame and blades.
- Application PC Case fan
- Frame dimension 120 x 120 x 25mm
- Fan speed 1200 RPM
- Fan airflow 38.4 CFM
- Fan air pressure 1.17 mm H20
- Fan life expectancy 20000/hrs 25ºC
- Bearing type Sleeve Bearing
- Connector 3-pin with RPM sensor wire
- Voltage rating 12V
- Current rating 0.15 A
- Noise level 17.5 dB(A)
- Product code AK-274CG-4GNS
Only £10.99 inc VAT.
ORDER NOW
Enermax UCAP12-G Apollish 120mm Green LED Fan @ £13.26 inc VAT
The Enermax 12 cm Apollish UCAP12-G fan cools components inside PC towers whilst emitting a cool light.
- Unique fan with Flashy colours and fascinating light effects
- Due to its patented circular LED lightning with up to 15 diodes (12cm model) Apollish shines four times brighter than ordinary LED fans
- Curved LED flashes
- Innovative and high-resistant coating for long-lasting brilliance and extraordinary light reflexes
- Persistent low noise level and long lifetime
- Patented Twister Bearing Technology with self-lubricating bearing sleeve guarantees a nearly frictionless and noiseless cooling as well as a longer lifetime (up to 100.000 hours MTBF)
- Excellent temperature-controlled cooling
- Integrated thermal sensor for optimized speed control
- Effective vibration reduction and comfortable installation
- Four isolator mounts reduce vibrations and make the fan installation easier
- Specificaton: Dimensions (mm) 120 x 120 x 25
- Bearing Patented Twister Bearing Technology
- Finish High-gloss and high-resistant coating
- LED type (patented) Switchable circular LED light with 15 diodes
- Speed (RPM) 700 ~ 1.700 (+/- 10%) | 25°C ~ 50°C
- Speed-Adjust Temperature sensor
- Airflow (CFM) 28.98 - 71.76
- Airflow (m³/h) 49.24 - 121.93
- Static pressure (mm-H²O) 0.853 - 2.030
- Minimal noise (dB(A)15
Only £13.26 inc VAT.
ORDER NOW
Xigmatek 120mm Crystal Green LED Fan @ £8.16 inc VAT
Come with Quad LEDs and transparent frame a/ blades. Combination design of special & large fan blade and efficient frame, Crystal series performs pushing max. airflow and min. amount of noise. To choose a Quiet, reliable, skinny and outstanding case fan, LED fan Crystal series is your best choice.
- Dimension: 120(W) x 120(H) x 25(D) mm
- Voltage Rating: 12 V
- Starting Voltage: 7V
- Speed: 1500 R.P.M 00 R.P.M.
- Bearing Type: Long-life bearing
- Air Flow: 68.33 CFM
- Life Expectance: 50,000 hrs
- Noise Level: <20 dBA
Only £8.16 inc VAT.
ORDER NOW
OcUK 30cm Cold Cathode 2-in-1 Kit - Green @ £7.14 inc VAT
CCFLs (cold cathode fluorescent lamps) are best suited for the interior lighting of PC systems. With an inverter they are connected to an unused 4-pin plug of the power-supply and can be used immediately. The CCFLs are 30 cm long.
- 2 CCFLs (same color)
- Self-adhesive pads
- 1 dual-inverter for connecting 2 CCFLs
Only £7.14 inc VAT.
ORDER NOW
OcUK 10cm Cold Cathode 2-in-1 Kit - Green @ £6.12 inc VAT
CCFLs (cold cathode fluorescent lamps) are best suited for the interior lighting of PC systems. With an inverter they are connected to an unused 4-pin plug of the power-supply and can be used immediately. The CCFLs are 10 cm long.
Only £6.12 inc VAT.
ORDER NOW
Akasa AK-178-GR 12" Cold Cathode - Green @ £8.16 inc VAT
A high quality one-piece Green Cold Cathode Light Kit that can be mounted without tools. Consumes just 3 Watts of power (less than a hard drive) and is supplied with additional power splitter for easy installation.
Only £8.16 inc VAT.
ORDER NOW
- 2 Year warranty
ORDER NOW
ORDER NOW
ORDER NOW
Only £8.16 inc VAT.
ORDER NOW
Only £7.14 inc VAT.
ORDER NOW
Only £6.12 inc VAT.
ORDER NOW
Only £8.16 inc VAT.
ORDER NOW
