Coolermaster CM690-II Windowed Side Panel
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys
I have managed to get some of the elusive side window panels from Coolermaster, the stock will be arriving on the 12th or 13th (next week) We have limited numbers arriving, only 50 units, with no ETA on any after that. I suggest you get your order placed now if you want one :)
Coolermaster CM-690 II Case Window Side Panel @ £19.99 inc VAT
Make your case components gleam with the new side window for all models of the CM-690 II case. Makde with an appealing design, much better than most generic square windows.
- 120mm vented fitment for side fan to give an optimal cooling solution
- Studded window fitment
Only £19.99 inc VAT.
ORDER NOW
Out of stock for ages when i wanted one last year... ended up getting some acrylic and getting my dad to make one ;)
here's the outcome for anyone interested -
Nice mod! How'd you achieve the nice clean edging?
Personally i would have put the window above the PSU thus hiding the cables a little more, but great finish nonetheless! [/jealous comment] :)
Delayed due to Coolermasters international shipping being delayed I'm afraid :(
We still have spare stock from the 50 units at the moment.
This is what I would like to know aswell. I have the windowed storm sniper panel and the window has been messed up. So I would also be buying a new acrylic sheet and then cutting and shaping it according to the original window design.
@ Alasdairhurst
Did you use sand paper to smooth out the edges?
@-=Vect0r=- & WingZero30
sorry for the late reply (i didn't have automatic email update set at the time.)
It was routed out and yes, some sandpaper was used to smooth the edges. :)
it's aluminium oxide sandpaper, because normal sandpaper would just wear down.
the acrylic is 3mm, though 5mm should be the maximum this close to the edge - a thinker piece i had, had to be shaped at a slant to fit over the fan at the back of the case.
also one thing you can note is that you dont have to cut the acrylic to shape, just leave it as a rectangle behind the shaped window :)
