Coolermaster CM690-II Windowed Side Panel
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys
I have managed to get some of the elusive side window panels from Coolermaster, the stock will be arriving on the 12th or 13th (next week) We have limited numbers arriving, only 50 units, with no ETA on any after that. I suggest you get your order placed now if you want one :)
Coolermaster CM-690 II Case Window Side Panel @ £19.99 inc VAT
Make your case components gleam with the new side window for all models of the CM-690 II case. Makde with an appealing design, much better than most generic square windows.
- 120mm vented fitment for side fan to give an optimal cooling solution
- Studded window fitment
Only £19.99 inc VAT.
ORDER NOW
Is it just me that thinks the side fan panel ruins the whole look? Especially when you have no intention of putting a fan on there anyway. Was after one of these as don't have the tools/experience to make myself one, but will have to order from a competitor as I'm not able to get free postage here.
