Coolermaster COSMOS Mod
10 Aug 2010
Somerset
My second, very simple case mod. Including painting the inside black, adding a custom COSMOS logo, and various holes for cable management.
Looks good.
Are you putting anything behind the logo panel? (dark coloured perspex to highlight the letters and hide the cables that are showing through).
Well my original idea was to cut out black acrylic the exact shapes and glue them in the holes. but that never worked! lol. But that sounds like a good idea, to neaten it up a little
How about some UV reactive perspex and light up the logo ;)
Looks really good mate, the cable management holes are really well done :) good job!
What did you use to tidy up the holes for the cables looks a lot neater. I would put a cathode or led strip behind the custom logo to show it off.
Good clean build.
Sounds like something behind the logo would be good, do OCUK do cathode or led strips? What about UV acrylic?
The edging around the holes, you just buy a strip of and cut it to length. Not sure where I got it from now but it's not expensive, and just hides the edges nicely I think :) Also gives a nice edge for the cables, so they dont get cut or anything.
