Coolermaster Cosmos S replacement 200mm FAN
26 Aug 2009
So my nice 200mm fan decided it doesn't fingers and threw two of its blades off. I was trying to find a replacement fan of the same dimensions of 200x230x30 but was unable to find an exact match. I did however find the Cooler Master MegaFlow but it is 30mm out. Does anybody know if it will still fit, even if not in the mounting holes but just in the actual housing as I can just glue it in place.
Thanks in advance
Get in contact with CM with photos and a copy of the reciept and they'll likely send you a new one (with a fan gaurd). This is/was an known issue that didn't affect everyone, but they had enough cases to warrent admitting manufacturing flaws.
On a side note CM customer support is a bit on the slow side, it took them 2 weeks to repsond to a query about my cosmos s! But when they did respond they offered above and beyond what i'd asked for so cant really complain.
Hmm love to know why I didnt think of that in the first place. I had power button fault and ended up with 3 new panels after I emailed three of their contact addresses lol.
Thanks I'll give it a shot.
