5 Jul 2010 at 21:12 #1 harryc harryc Associate Joined 6 Aug 2008 Posts 35 will the Coolermaster Elite 335 be able to fit in a XFX ATI Radeon HD 5830??? want to make sure before i buy
5 Jul 2010 at 21:34 #2 chipps101 chipps101 Soldato Joined 8 Jan 2010 Posts 4,108 Location Dundee yes it will fit with ease, that 5830 is a small card.
5 Jul 2010 at 23:27 #3 MeatLoaf MeatLoaf Soldato Joined 1 Dec 2005 Posts 14,697 Location Stoke on Trent yes it will be fine
6 Jul 2010 at 09:29 #4 DELETED_83755 DELETED_83755 Associate Joined 19 Jun 2009 Posts 1,306 What I found will the coolermaster elite 335 is that you can't have a hard drive directly in line with a long graphics cards. But if you put the hard drive at the bottom or top then its all good, it will fit!
7 Jul 2010 at 19:44 #5 harryc harryc Associate OP Joined 6 Aug 2008 Posts 35 ahh cheers, another thing might sound noobish though lol, but how the hell do i get the front panel off?? :S
8 Jul 2010 at 10:05 #6 DELETED_83755 DELETED_83755 Associate Joined 19 Jun 2009 Posts 1,306 There are pegs on inner part of the front of the case on both sides, just push them all out with fingers or pliers. Then there is a gap on the front bottom of the case where you can put your hand to remove front panel.
