Coolermaster Excalibur
25 Oct 2009
Caerphilly
Coolermaster Excalibur Case Fan.
:eek: Sexy looking thing this.
Seems to shift a lot of air at 2000rpm.
Features
  • The innovative Barometric Ball Bearing technology provides longer life span while remaining lower noise level.
  • Removable blades for quick and easy cleaning.
  • Nine massive sword-shaped blades generate outstanding high air pressure with balanced airflow.
  • Triangular blade tips reduce turbulence at fan edges and decrease wind shear noise while keeping maximum sweeping area.
  • 3-piece frame with metal rim provides robust structure.
  • Honeycomb ventilation meshed frame:
  • - Low speed operation works as a secondary intake to increase airflow.
  • - High speed operation helps to reduce noise by releasing excessive turbulence and vibration.
  • PWM function for total performance solution at high and low speed operation.
