- 8 Jan 2019
- MSI HQ
CoolerMaster have a new entry into the Mini-ITX Market and it's like their design team cut a H500 in half with a chainsaw!
With the CoolerMaster Elite-130 Mini-ITX coming to the end of it's life, the H100 is a refreshing new look at the Mini-ITX form factor.
The H100 features CoolerMaster's "Fine Mesh" on the Front and Top Panel, which is designed to allow as much airflow as possible whilst keeping dust to a minimum. Couple this with a Massive 200mm RGB Fan and you have some serious cooling potential in a small case!
CoolerMaster Mastercase H100 - RGB Mini-ITX Case - Black @ £54.95 inc VAT https://www.overclockers.co.uk/coolermaster-mastercase-h100-rgb-mini-itx-case-black-ca-37x-cm.html
USB 3.0, Mini-ITX, 200mm RGB Fan, RGB Controller, Space For ATX PSU, Steel Side Panel, CoolerMaster "Fine Mesh", Built In Handle
Only £54.95 inc VAT.
ORDER NOW
ORDER NOW
