Coolermaster HAF 912 Plus Case
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys,
I have secured all the UK stock on the HAF 912 Plus case from Coolermaster for launch. So if you want to avoid disappointment buy now. There are only 80 pieces arriving to the UK. All headed into the OcUK warehouse :)
Coolermaster HAF 912 Plus Case - Black @ £69.99 inc VAT
Cooler Master adds another new member to the HAF series, the HAF 912 Plus. To carry the mission of providing the best thermal solutions, HAF 912 Plus supports two 120 mm for external radiator and high-end CPU coolers. Furthermore, the spacious interior accommodates two 200mm fans and two-- 120mm fans for better and superior airflow yet, enough to fit 12 devices and high-end GPUs such as Radeon HD5970 and Nvidia GTX 480.
- Superior cooling performance support up to two 200 mm and two 120 mm fans
- Front 200mm fan with brilliant Red LED provides the best airflow to HDDs
- Removable 3.5”HDD cage provides enthusiasts more convenient installation
- Customized neat cable management
- Dimensions 230 x 480 x 496 mm (WxHxL)
- Weight: 8,45 kg
- Motherboard Support: ATX, Micro-ATX
- Front Cooling: 1x 200 mm (19 dB(A), 700 RPM, Red LED) or 2 x 120mm fans (optional)
- Top Cooling: 1x 200 mm or 2 x 120mm fans (optional)
- Rear Cooling: 1x 120 mm (17 dB(A), 1.200 RPM)
- Side Cooling: 1x 140 / 120 mm (Optional)
- 5.25" Drive Bays: 4
- 3.5" Drive Bays: 7
- 2.5" Drive Bays: 4
- Expansions Slots: 8
- Front I/O Ports: 2x USB 2.0 / 1x eSATA/ 1x Audio In/Out
- VGA Card Size: Up to 39 cm
Only £69.99 inc VAT.
ORDER NOW
still looks nicer than a antec 902, plus easier for cable tidy and cooling.... not going to buy it as i`m not in the mood to buy a case to get rid of a case lol..
still the usa version looks a good price but don`t forget to factor in the cost to send it here and the customs as well.
ocuk have a very good price. plus it is limited :D
Yeah I am not blaming OcUK.
Its probably made in China, so shipping is mute as China -> USA isnt a lot diff from China -> UK. But then if they are going China -> USA -> UK well yeah ;)
There will be some taxes on the NewEgg pirce as well I am pretty sure, could be wrong though...
Its good and not unreasonable price just imo could be £10-£15 cheaper if it was US version and blow the competition away. Quite interested to see if the US version makes it here elsewhere, historically manufacturing Companies attempts to limit/prevent this sort of thing haven't succeeded that well.
