Coolermaster hyper 212 evo vs bequiet pure rock 150w
12 Apr 2007
Hi all
So I currently have a hyper 212 evo installed, and have just pulled this coolermaster out of an old rig as a salvage part.
Question is, is it worth swapping them over?
They are both very similar in terms of size and design, so is it worth the effort?
Thanks.
Is it a bequiet Pure Rock or a Cooler Master?
Probably not worth swapping - unless you're unhappy with noise or temperatures, the PR looks fairly 212-ish.
Edit: derped on OP's derp :P
While BeQuiet is bigger and heavier difference isn't that big.
So any cooling difference likely isn't really significant.
Though if you don't have anything better to do and have thermal paste...
