Coolermaster LABS Tech Bench ** PRE ORDER NOW **
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
*** *** Coolermaster LABS Tech Bench @ £84.99 inc VAT *** ***
A bench table is ideal for system builders, component testers, benchmarkers and for people who just want something a little more unique. This open ended bench table provide the ultimate in air-flow and quick access to all your components, alternatively you can install a water cooling setup on this bench with space for radiators, pumps and reservoirs.
- Dimensions: 320 x 100 x 282 mm
- Material: Steel
- Weight: 1.8kg
- Form Factor: ATX, Micro-ATX, Mini-ITX, Pico-ITX
- Bottom mounted PSU area
- Reset and power on/off switch
- Rubberised feet to give maximium grip and minimal vibration.
Only £84.99 inc VAT.
ORDER NOW
Is it really worth it? For one thing, you can just run it in the motherboard box. And for another, anybody with access to some decent tools could make something identical to this for less than half the price, without having the Coolermaster logo's on all your pics...
It's cheaper than most other test benches. So if what you require is a pre-built test bench then I guess it's one of the better options.
So it gets the no vote then, I agree, the skeleton looks far better, this looks like I made it in my workshop (well without the decent paint job) lol
cant see the point in this myself, if it was £30 maybe...all the other "test benches" ive looked at seem to have something interesting about them.
