Hi Guys,
So as most of you are aware recently Computex happened revealing some of the new technology that we have to look forward to. Some will come to market right away and some will be sometime in the coming months.
Well Cooler Master has started to release some of the coolers already from the even starting with the MasterAir 8 cooler.
This cooler uses Cooler Masters patented Vapor Chamber technology to help to improve the cooler market in a positive way. The 8 heat pipes allow the cooler to reduce the heat from the CPU and allowing you to push your CPU that little bit more.
The cooler also comes with Cooler Masters highest quality Silencio FP fans.
The cooler will be in stock from The 15th June.
Take a look a the Cooler details below:
Cooler Master MasterAir Maker 8 CPU Cooler @ £99.95 inc VAT https://www.overclockers.co.uk/cooler-master-masterair-maker-8-cpu-cooler-hs-074-cm.html
CPU Socket Compatibility, Intel® LGA 2011-v3 / 2011 / 1366 / 1156 / 1155 / 1151 / 1150 / 775, AMD FM2+ / FM2 / FM1 / AM3+ / AM3 / AM2+, Warranty 5 Years
The MasterAir Maker 8 has landed. It’s designed for gamers and overclockers who demand ultra-low temperatures, aggressive LED lighting, and total control over their hardware. A seriously sizeable unit bursting at the seams with our newly patented 3D Vapor Chamber technology, your system will look amazing and stay rock solid even during intense gaming and overclocking. And yes, you can customize the outlook with two bundled top cover designs, as well as adjust the fan size, model or position for memory or graphics card clearance.
3D Vapor Chamber
For the past five years, Cooler Master's engineers have been hard at work tinkering and toying with our patented Vapor Chamber technology in a bid to reinvent how heat-intensive components can be cooled. After countless trials and rigorous testing, we've seamlessly combined Horizontal Vapor Chambers with native heatpipes. The result? Superior air cooling that better protects your advanced components from overheating and damage.
So what are Vapor Chamber and 3DVC technologies? To put it simply, we've tossed out the traditional copper base that transfers heat away from the CPU and replaced it with a coolant filled VC. When these VCs are heated, the coolant transforms from liquid to gas and back again to protect your CPU from overheating. How? That's need to know info you'll need to head back to school (or the CM university) to comprehend.
All you need to know is that the process swiftly cools your hardware, and that in 3DVC, heatpipes and the horizontal base are seamlessly connected, helping to increase performance compared to conventional copper base air coolers.
Customize to Your Heart's Content
Do you prefer a clean, professional-looking workstation or bright LED lights that accent your gaming rig and match your color scheme? Choose your style with interchangeable top covers (included), opting for a translucent plate that showcases the MasterAir Maker 8's LED lights, or an aluminum plate for a clean and stylish finish.
3D Printing
We know the community also has some awesome ideas, and the ability to express them in everything you make or do. So with that in mind, we're set to release the 3D printing schematics of the top.
Want to 3D print a creative design or image on the top cover? Go for it. Or what about creating a LED light fixture or 3D model that protrudes out of the air cooler like alien?? Well if you can design it and actually fit it onto the cooler, then why not? 3D print to your heart's content and make the MasterAir Maker 8 truly yours.
Designed for Gaming and Overclocking
Long hours of gaming or overclocking requires an air cooler that can handle your CPU's Thermal Design Power (TDP), and meet the increase in power consumption. The MasterAir Maker 8 gives you peace of mind with a high 250W TDP, helping to protect your system from becoming unstable or shutting down during intensive gaming and overclocking. Plus it looks totally badass.
Silencio FP Fans
The MasterAir Maker 8 comes with the highest quality Silencio FP fans. These fans include Cooler Master's exclusive Silent Driver IC technology. Make no mistake - the MasterAir Maker 8 is a high performance air cooler, yet the two Silencio FP fans combined output registers at a surprisingly low 8-24 dBa, making it one of the quietest choices when it comes to high-pressure cooling. The self-lubricating and dustproof design also keeps the blades operating smoothly, ensuring a new system will likely be long obsolete by the time these fans expire
Specifications:
Model: MAZ-T8PN-418PR-R1
CPU Socket:
Dimensions (LxWxH): 135 x 145 x 172 mm
Heat Sink Dimensions (LxWxH): 78 x 144.5 x 160.5 mm
Heat Sink Material: 3D Vapor Chamber Base / 8 Heat Pipes / Aluminum Fins
Heat Sink Weight: 758g
Heat Pipe Dimensions: 6 mm
Fan Dimensions: 140 x 25 mm x 2pcs
Fan Speed: 600 – 1,800 RPM ± 10%
Fan Air Flow: 19.8 – 66 CFM ± 10%
Fan Air Pressure: 0.24 – 2.2 mmH2
Fan Life Expectancy: 160,000 hrs
Noise Level: 8~24 dBA
Bearing Type: Loop Dynamic Bearing
Connector: 4-Pin
Rated Voltage: 12 VDC
Rated Current: 0.15 A
Power Consumption: 1.8 W
Fan Weight: 130 g
Weight: 1350 g
Warranty: 5 years
Only £99.95 inc VAT.
ORDER NOW
3D Vapor Chamber
3D Printing
Silencio FP Fans
Specifications:
CPU Socket:
Connector: 4-Pin
Fan Weight: 130 g
Weight: 1350 g
Warranty: 5 years
ORDER NOW
