Coolermaster Mystique
16 Oct 2004
Ive got a Coolermaster Mystique and I want a side window so I can see my lovely 8800 but coolermaster don’t seem to do one for the mystique. They do one for the wavemaster and I know they are very similar cases. So I was wondering if the wavemaster window side panel will fit the mystique??
Anyone tried it??.
ive got a good feeling that the wavemaster side pannels did fit some of the other cm cases unfortunatly i cant remember which ones :(
I'm also a Mystique owner (in black) I think your chances are pretty good, I found this picture on a competitors site. However it wasn't listed as an individual item only under the full case. If this is not already on sale, then they should be able to give you a date at least.
That case looks very nice, what do you guys think who own these ?
It's a nice case to build with, however it does lack some of the overall build quality of older coolermaster cases like the 201 etc but that can be said of certain coolermaster cases anyway:) I had some issues with the drive rails not wanting to clip on my drives properly and the drive locks not shutting correctly but that down to it being a new case, but I manage it both problems out.
The case cooling is great with 2x 120mm Case fans (1x Front & 1x Back) noise wise it's quiter than my 201 was:p
Overall it's a great case :)
Anyone tried it??.
Any chance of some pictures of the existing side panel, and the side of the case with panel off - i'll hopefully be able to tell you if the wavemaster window will fit then
