Coolermaster Praetorian 731-Modding the side panel
11 Jan 2007
Hi Everyone,
I have just purchased this case and although I love it, the side panel is hideous, I simply do not like the exhaust and acrylic/gauze effect, plus I can only at themoment use the stock Intel cooler on my 6600 which i know will clock higher, but with the exhaust there, a cooler such as the Scythe infinity wont fit!
Can anyone advise me if there is a place that sells replacement side panels for this case that have a window, or is there somewhere that will convert my existing side panel to a window one?
I would try myself but I would rather pay someone to do a professional job as I would ruin it.
Please help.
There is one easy solution:
This was needed because the cooler came out this far:
Doesn't look very pretty, but works just fine.
M
