Before today I thought this was a brilliant case.
I got one for my brothers latest build 6months ago. I helped him put everything together and so far its been brilliant.
6months have gone and i offered to clean it out for him.
As i was teaching him at the him we simply plugged everything into the correct sockets and it worked.
After cleaning it out i decided I'd tidy it up a bit.
description of the case:
This case cannot route cables at all! it has the holes at the bottom and top to pass the cabled through but you cannot have ANY cables running behind the mobo panel otherwise the rear door won't shut! the cables won't allow it to lock!
Has anyone managed to successfully route cables around it? i spent 30mins making it look neat and tidy to find the door wouldn't close!
Angry to say the least!
- Soundproof materials applied to build a quiet environment
- Sound barrier design reduces vibration for silent operation
- Dual bottom air intakes to enhance air flow and reduce system noise
- Six aluminum detachable HDD modules with ventilation holes for optimizing cooling
- Side removable VGA cooling tunnel to advance thermal airflow
- Patented finger pressing buttons for quickly maintaining or upgrading 5.25” drive
- Tool-free design for opening side panel conveniently
- Separate HDD modules make it easy to organize
- Cable management system for better cable routing and neatness
- Motherboards E-ATX, ATX,
- Cooling System
