- 6 May 2011
Hi
I have just put my kit into a Coolermaster S but can seem to be able to connect the power button cable -
According to their webiste there should be an MB Power extension cable into which the power button plugs, but my cable has a black connector on the end so I can't see how this would connect even if I had the extension cable:
Here is the pic from Coolermaster:
http://www.coolermaster.com/faq.php?action=ViewAnswer&faq_id=293
Not sure what to do
Thanks
Not sure what to do
Thanks
