hello guys i will try to explain what the problem is here
http://www.coolermaster-usa.com/product.php?product_id=2949
now the problem that i have is the connection which goes into the motherboard has become faulty but not all of it the connection is a 20pin connection but it has a 4pin added to the end to make the whole 24 pin connection now this cable is actually hard wired to the power supply itself so i cant just take it off and replace it is there a way i can like a pin connection to 4 pin to replace the faulty 4 pin connection on the power supply i hope that makes sense.
thank you
thank you
