Coolermaster Sniper Buzzing Case
5 Jan 2005
South East, UK
I've never been happy with my coolermaster sniper case. One of the sides does not completely slide in to the front as it should and it has a tendency to develop a buzzing noise from vibrations after a while. I then have to pull the top of the case sideways a little and the noise goes away (for a while). I should have returned it when I got it but I had already installed the system when I fully realised the issues and being in the midst of Warcraft addiction at the time I failed to do so.
Is the case buzzing a common problem and what would you recommend for a fix?
