Coolermaster Stacker 830 Evolution 'nVidia'
31 Jul 2008
manchester
hi
i have just been offered this case at a good price with 3 extra green fans the case is less than a year old . basicley new (have seen it)
has anyone got on of these on here or similer . if so any veiws on it? or anything . i have looked at a few reveiws well there is only one that the nvidia version was reveiwed others were the 830.. looks a nice case only thing is all them fans in i.e cfm and only one rear fan thats the only thing that got me..
thanks
I had a Stacker 830.
Good case imo.
The 4 120mm fans on the side fit into a plastic door which you can remove ( it unclips ) if you don't want them.
There should also be a 120mm in the roof as an exhaust.
I sold my 830 for £70 ( bought it " as new " for £90 - 2 years previously ) .
I wouldn't pay extra for the Nvidia branding ( unless you like green ! ).
I had the nvidia one, case had some vibration, the side fan cage was useless with a large cooler as the fans wouldnt fit due to the depth of my thermaltake.
Nice case if you can put up with that.
Good case imo.
yea thats what the price is £70 + 3 akasa green fans
so Basicley the case is 220 wide (inside) due to that fan holder .. also what thermatake was it extreme???
i got it and sold me old case for £40 this case cost me £30 with 3 extra fans nice one
i am now all green :) lol
anyway thanks for replys all ;)
