Coolermaster Stacker 832
18 Oct 2002
watchin scrubs.
Hi All
Ive had this case for a while now and am pretty pleased with it, however it does have one trate that hacks me off...
The side panels fit very poorly, they fit in place but are some what loose, to the point where they rattle. For the price of this thing you would think it would be near faultless.
Does anyone else's side panels fit rather 'loosely' ?
Is this a general 'Stacker' problem?
Mine didnt do it when i first got it then i took the panels off a few times and then it randomly started doing it. I thought it was something else rattling but then i just adjusted them a little bit, you can slide them back slightly or something and its never done it since
