- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Coolermaster Storm Case Range down in price.
The Coolermaster Storm 'Sniper' Gamer Case - Black (No PSU) is only £116.99 inc VAT.
CM Storm proudly unveils the Sniper™ gaming grade PC chassis, developed in cooperation with the world's leading professional gaming teams, including SK-Gaming, Team Fnatic and mousesports. Featuring CM Storm's radical new doctrine, Storm Tactics™, which emphasizes Strength, Security and Control, the Sniper is designed to satisfy the lifestyles and unique needs of hardcore and casual gamers alike.
The Sniper features unprecedented airflow from up to three huge fans: a 200mm blue LED fan in the front, a top exhaust 200mm LED fan and yet another optional 200mm VGA intake, all backed up by additional 120-140mm fan locations (6 in total), creating some seriously heavy duty airflow to cool all your high-end PC components. Developed with elite engineering skills, and reinforced by the highest grade materials, your Storm gear will perform and deliver with unfailing reliability, letting you focus on your game and worry less about your hardware.
The Sniper offers a built-in one-for-all fan controller, which lets you tune your airflow to find the perfect balance between thermal performance and silent operation. Integrated in the extra large control knob is a LED light switch, letting you decide exactly when to turn on the lights for a full-on gaming session, and when to chill out in the dark with your favorite movies. Furthermore, the Sniper gaming chassis features convenient carrying handles for fast and efficient mobilization, multi-position water cooling holes, tool free design, and great expandability for peripherals, HDDs, optical drives and function panels. Injected with Storm Tactics, the Sniper lets you tweak and tune your hardware to work just the way you want it.
- Steel Case
- 5x 5.25" Drive Bays
- 5x 3.5" Drive Bays
- I/O Front Panel: USB2.0 x 4, IEEE1394 x 1, eSATA x 1, Mic x 1, HD Audio x 1
- Cooling: Front: 200x30mm Blue LED Fan x 1 (500 - 1000rpm, 17 - 23 dBA);
- Top: 200x30mm Blue LED Fan x 1 (500 - 1000rpm, 17 - 23 dBA) (can be swapped for two 120mm fans or 120x240mm Radiator)
- Rear: 120x25mm Standard Fan x 1 (1200rpm, 17 dBA) (can be swapped for 90mm fan or 80mm fan)
- Bottom: Supports 140mm Fan x 1 or 120mm Fan x 1 w/ Dust Filter (optional)
- Side: Supports 200x30mm Fan x 1 (optional) 220x25mm Fan x 2 (optional)
- Dimensions: 56.6cm (D) x 25.4cm (W) x 55.1cm (H)
The Coolermaster Storm 'Scout' Gaming Case - (No PSU) is only £69.99 inc VAT.
CM Storm is celebrating the deployment of the Scout™ true gaming chassis, created in close cooperation with the world’s leading professional gaming teams and eSports organizers, including Kode5, Team Fnatic and mousesports. Like all gear developed in the CM Storm Labs, the Scout has been heavily injected with Storm Tactics™ to ensure complete Strength, Security, and Control to the discerning gamer. Developed with elite engineering skills, and reinforced by the highest grade materials, your Storm gear will perform and deliver with unfailing reliability, letting you focus on your game and worry less about your hardware. The Scout has been built around a solid steel body, and comes equipped with a 140mm front intake fan, as well as 140mm top and 120mm rear exhaust fans, providing an accurate airflow to efficiently manage the heat from your gaming hardware. The aggressive window side panel, with its dark automotive tint, provides mounting locations for yet another 2 x 120mm fans to deal with thermal hotspots from overclocked CPUs and GPUs. The Scout has been fortified even further with the patented StormGuard™ accessory; this unique and widely acclaimed security solution from the CM Storm Labs consists of a specially designed PCI-bracket located at the rear of the chassis body. By locking your peripherals and side panel firmly in place, Storm Tactics and the StormGuard will protect your PC and gaming gear from thieves and other thuggish individuals whenever you are AFK. Never again return to your seat at a LAN-party, only to find that some villain has grabbed your gaming mouse and headset, or even worse, your entire system.
- Solid Steel Body for strenght and stability
- Features sturdy carry handles for taking to your favourite LAN events
- Unique security feature protection for your system and peripherals
- 4 x 5.25" drive bays
- 5 x 3.5" drive bays
- Bottom mounted PSU support
- Front I/O Port: eSata, FireWire, 4 x USB, HD audio
- Front Cooling: 140mm intake fan (included)
- Top Cooling: 140mm exhaust fan (included)
- Rear Cooling: 120mm exhaust fan (included)
- Side Cooling: 2 x 120mm intake fan (optional)
- Steel Case
