Coolermaster Storm "Scout" Gaming Case
8 Mar 2010
Will this case be able to fit in the £580 overclocked i7 Bundle, and provide enough cooling to keep this running smooth?
Ill probably be choosing a 5850 or 5870 to go with.
So just want to know if there's anything better for same money, or if this will not suffice, cheers.
Cooling is excellent. 140mm intake in the lower front, 140mm exhaust in the roof and a 120mm exhaust in the rear. I added another 120mm intake above the 140mm at the front of mine. You can also add a pair of 120mm fans to he side panel. The front is all filtered too. Biggest graphics card it will take is 10.5". It's a good little case with good cable management and a nice black interior.
Well the 5850 is classed as a 10.5" card, and it can fit a 10.5" card with the PCI-E connectors sticking out the back, and the 5870 has the connectors coming out the top, so both should fit (as they are essentially the same length).
