Coolermaster Storm Sniper owners.
10 Mar 2009
Hi there,
Is it possible to remove the tooless clips from the expansion slots and use screws or thumb screws?
Thanks for any help.
If those clips are like the storm scout ones, then yeah - they are crap, two of mine snapped off. I just use thumb screws in mine now.
Thanks for the replies.
Had heard bad things about those clips but if I can use screws then its not a problem.
Think this might be the case for my new build then. :)
