Coolermaster V850 Rear Pinout
23 Nov 2002
Near Bristol
Hi Guys,
Anyone know where I can find the pinout diagram for the Coolermaster V850? I've had a bit of a google but I'm none the wiser. It seems to be based off the Seasonic KM3 platform, but they've also changed the size and placement of some of the connectors on the back so that doesn't really help. That and the cables are black, so I cannot identify them that way.
Any help would be much appreciated.
Thanks,
Mark
I had the same thought before listing this thread up, unfortunately it only shows the pin out from connectors on the ends of the cables, rather than from the connections on the rear of the unit. Appreciate the suggestion though.
