- 7 Oct 2004
So basically for my new build im going with a new case, my current case is the Thermaltake Armor, its a nice case, but after looking at it for 5 years its time for a change.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-156-CM
The CM RC-1100 Cosmos S got some great reviews, but people said cable routing can be an issue due to its small space behind the motherboard tray, also some complained there was no reset switch on the case ( how big of an issue could this be )
For the other cases, ive been looking at the Lian Li cases, some of them are very sleek looking, and have some great reviews aswell, ive also seen that some members on the forums have them and cable routing allows for awesome airflow, but what one is better
Lian Li PC-A71FB
http://www.overclockers.co.uk/showproduct.php?prodid=CA-172-LL
or
Lian Li PC-A77FB
http://www.overclockers.co.uk/showproduct.php?prodid=CA-196-LL
The A77 seems to have a more open front on it, does this increase the noise from the case a lot.
Suggestions?
Lian Li PC-A71FB
or
Lian Li PC-A77FB
Suggestions?
+1 for lian li A71f cuase i have one, a very versatile case depending on your needs,
