Craig321 said:Hi,
I found a coolermaster wavemaster side panel on a certain hardware website (competitor).
Has anyone got one/have any decent sized/quality pictures of it please?
Thanks,
Craig.
Yewen said:I can provide pictures of 201's with windowed side panels if that would do, they are the same panel although the colour of the window may be slightly different.
Interested in those?
Mikey1280 said:Ichabod Crane made his own side panel, I'll try and find some pics, its really good
EDIT: here you are
http://img433.imageshack.us/my.php?image=dsc007285pt.jpg
Jakal91 said:snip
please don't quote them either!
Harib0 said:You can see the silver panel with veridant window for the wavemaster on my 111 click the link in my signature for pictures, I also have a silver panel with blue window here if you want me to take pictures of it for you - i've never used it so it's packed away, but i can get it out if you want to see it.
Yewen said:
Craig321 said:Oh also, a little off-topic here. But does the Wavemaster come with a converter kit thing to convert the top ports into a fan?
Thanks,
Craig.
Craig321 said:Hmmm, yes, it is rather large
It looks like glass in the pics, is it? Wouldn't have thought a glass side panel would be only £20
Harib0 said:No it's not glass it's acrylic, that window is the verident colour, has a slight green tinge to it, giving the impression it's glass i suppose, there is also a blue acrylic version.
I think it depends how you cable tidy and lay out your case
goreblast said:Do windows that are marketed as for the wavemaster case have 3 screw points on them? and if so which ATC cases do they fit?
sounds pretty sweet, i suppose after this is done the case would benefit from a better outake fan than the standard one as theres should be more in take than outtake, actually, 2 blocked out fans and a working one would probly level out with 2 outakes and the gfx card outake. wait and see i supposeYewen said:Yes I am planning on doing it, just got to get enough time to do a good job of it.
Will be doing a full guide to doing it, if its for good or bad, but it should be good as I have never tried a blowhole on the bottom of the case, if it works it should be very very nice!
Depending on the fan I recon it could add better cooling than any of the old ATCs cases at silent levels, just by sheer amount of fans.
Give me mid July and I should get it done. Going to do a mockup on another case first to see what to expect. That should be before the end of this month hopefully, will be doing it to a charity PC.
I will be keeping people up to date, but it will probably take me a whole day tto do the mod and then a few hours for the guide, I don't do things by half and I need to work out the best filtration system for a fan pointing to my floor!
Will be more news, if you want more info on what I have planned feel free to add me to MSN and I can give you some speil on why I think this will solve the trouble with the Wavemaster and SLI, as ultimately this is the reason why I am modding the case.
