Coolest Graphics Card?
2 Oct 2006
Hello, i have £140 to spend on a card, i am opting for the ATI4850, however i hear it runs extremely hot, and combine that with a silverstone sugo1 lan box, it's not gonna go to well, but it would be the best card for my budget, so what i am asking is, which version runs the coolest :D
Although I can't say for sure, I'm fairly certain this will be one of the coolest (albeit the most expensive)
http://www.overclockers.co.uk/showp...3 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail
It'll vent the air out of the case too, which always helps for small cases.
If it has to be single slot, there really is only the stock single slot cooler that comes with the standard model, and tbh, it does the job.
