after buying the very hot amd 7950 i have had to do all sorts to keep it cool, the next step has/is voiding the warranty of the card, i want to add an after market cooler. my plan was to add another card but without having to deal with the heat of it, which card should give good temps without having to change to aftermarket heatsinks.
thanks
thanks
, that iceQ has a blower so guessing I wont have the hot air floating around inside the case?
