- 20 Jul 2006
As the title says what is the coolest running dual core lga775 cpu, want to use one for a HTPC, graphics card will do the decoding so cpu speed does not matter a 1.6GHZ dual core is more than enough, will be using in a case with limited ventialtion, so need one which runs very cool, I have the E1200 Celeron in mind, but then there is the pentium dual core e5200, both rated at 65watts, but is there much temperature difference between them
Will be using Silverstone NT07 LGA775 CPU to cool it..
