Cooling 2 GTX 770's?
2 Sep 2010
Hi all,
I've 2 cards in SLI at the moment:
MSI GTX 770 twin frozr
Asus GeForce GTX 770 1058MHz 2GB PCI-Express 3.0 HDMI DirectCU II
Don't hotlink images - Rilot
These are currently in a Fractal Design Define Mini (incidentally this picture has a similar CPU cooler as I have now):
The SLI slots on my motherboard are next to each other so that the 2 GPU's sit tightly on top of each other. So I have to find 2 watercooling solutions for 2 different 770's that will work in my case.
I've looked around and found this one for the ASUS. I don't think there's a full cover for the MSI? I need some help putting a WC system together (if there's a closed loop kit that would be preferrably)
EK Water Blocks FC770 GTX GPU Water Block - Acetal+Nickel
thanks guys
If you want to go down the water cooling route, you could just watercool the top car and have the lower card as aircooled.
i did this with GTX 680 SLI for a while.
That is a good idea actually, didn't think of that! Any idea which of the 2 cards I have that I should WC?
Thanks all. Will this work? I threw in a CPU cooler as well and changed to two 120mm radiators.
YOUR BASKET
1 x EK Water Blocks FC770 GTX GPU Water Block - Nickel £88.14
1 x EK Water Blocks EK-DCP 4.0 X-RES (Incl. Pump) £81.99
1 x EK Water Blocks EK-Supremacy £51.24
2 x XSPC EX120 120mm Radiator - Black £32.79 (£65.58)
2 x Primochill Primoflex Advanced Tubing 16/11 - Clear £6.14 (£12.28)
2 x Mayhems Ultra Pure H2O Watercooling Fluid 1L £5.12 (£10.24)
10 x XSPC G1/4" to 1/2" Barb Fitting (Black Chrome) £1.83 (£18.30)
Total : £340.10 (includes shipping : £10.00).
States you need the FC-770 GTX DCII, the ocuk link is to the standard version. Look at the block on the EK link you posted it clearly looks different.
Ocuk link
http://www.overclockers.co.uk/showproduct.php?prodid=WC-395-EK
You need
http://www.coolingconfigurator.com/upload/pictures/780DCII-NP-1_800.jpg
Yes, thank you! Are the rest of the components OK? 2x 120mm rads won't cause any issues? I'm thinking perhaps one in the front and one in the upper rear of hte case, or the top.
What case do you have? If I'm honest I'm not to clued up on water cooling. A single 240 rad would be better than 2 individual rads and having a total of 240 rad space seems borderline for a gpu and CPU to me.
