Cooling a 9900k
8 May 2013
Durham
Hi All, looking for a cooler for my planned 9900k build. I'm not comfortable doing a custom loop so will be looking for a high end AIO. Does anyone have a 9900k and what cooler do you use and temps. I'm probably looking at doing a 5ghz on all cores if possible.
What case do you have? Even then I can't say what temps will be when overclocked even with case fans setup so cooler is getting air at or near room temp.
Corsair 750D Airflow edition. 2 140mm front fans 3 140mm top and 1 140mm rear. I currently have the H100i v2 on a 4970k @4.6
