I just got this case and I'm wondering the best way to increase the cooling slightly without adding noise. It comes with 1 intake and 1 exhaust so would i be better adding another intake or another exhaust?
I think adding a bottom 140mm fan will help your GPU temps considerably. Being at the bottom it's harder to hear as well if your case is on the floor. I find top exhaust fans aren't amazing, and are easier to hear.
I also found that the stock fractal fans are very whiney at full RPM in my Arc. I have to run them at 7V.
Do you want more GPU cooling or more CPU cooling? Intake will help both more than another exhaust in my opinion.
Do you have the top hard drive cage removed to improve airflow from the front intake?
