For a cheap upgrade i bought a 3ghz processor
http://processorfinder.intel.com/Details.aspx?sSpec=SL79L
The cooler i have is really not up to the job, it was fine with the 2.6ghz cpu i had over clocked to 2.9 but it idles at over 50 degrees now lol
Any recommend a cheap cooler thats up to the job of a prescott?
Obviously its old hat technology so wasting money on a new cooler on a old cpu would be annoying.
I assume buying one of the genuine intel h/s/f off the bay that say they are off a p4e are not good?
Anyone have any ideas?
, you don't need any other bits apart from that which is already fitted to the motherboard and the fan and fittings itself?
