I recently purchased a opteron 175, a friend of mine told me that the stock cooler would be sufficient for the CPU. When under full load it reached 82C so i'm assuming his suggestion was wrong.
I've got a used Arctic Cooling 64 pro, if i cleaned that up and applied some fresh heat conducting paste would that be sufficient to run it at stock speeds (for now), or am i going to need to invest in a newer model of heatsink?
If i do need a new-un what are your recommendations? The quieter and cheaper the better.
