Hi,
I'm new to the forum and new to water cooling, so I apologise if I ask the same questions as others. I have done some research on the topic, but would still appreciate some second opinions.
The goal: a silent system. I need to record audio alongside video tutorials and silence is important to me. I am not really interested in overclocking for this pc (also I believe I read HP locks that away in the BIOS anyway). Also it is not really required to cool the graphics card at this moment (unless you guys think that would be a good idea as that might produce a lot of noise too).
As I mentioned the current system is based on a hp xw8400 workstation:
http://h10010.www1.hp.com/wwpc/ca/e...2712-12132712-12132712-12431664-80699851.html
But has this CPU in it:
http://www.firingsquad.com/hardware/intel_quad-core_xeon_5365_v8/
I've just upgraded it with an Evga geforce 580 gtx and I'm expecting to upgrade the ram to 22Gig.
The problem lies with the current fans on the cpu blocks, the block are fairly close together and the fans make too much noise when I am using the procs fully.
Here are pictures of the approximate layout of the motherboard:
http://community.avid.com/forums/p/38873/217389.aspx
So what I would like is to replace those fans with water cooled cpu blocks. But I have little experience with this.
*) Cpu block(s):
So far I have found out the cpu socket is LGA 771 (or FC-LGA6, but definitely not LGA 775), which should work with a EK supreme HF block.
*) pump: a Laing D5, probably a Swiftec mcp 655
*) reservoir: no clue yet, I don't know how important that is or if size matters.
*) radiator:
-> could be passive? I don't really mind something like a resorator, but I don't know if that will cool enough for both cpu's. I'm ok with it if it is external as there is very limited amount of space inside the case.
-> Otherwise perhaps that Black Ice 360, but again external.
I would appreciate if you have suggestions for the radiator.
*) tubes: probably 1/2 inch
*) fittings, compression seems more durable and easier to use to me. Not really sure what angles I will need around my cpu blocks. I guess 2 x 90 degree bends (to bridge the gap inbetween) and 2x 45 degrees to connect to pump and reservoir.
As this is more a productivity rig, I am less concerned about aesthetics. (No need for lights or Uv reacting tubes etc...). Just silence really
Thanks for any advice you can give me.
*) Cpu block(s):
*) radiator:
