Hi Folks,
Just need some advice with my new rig if possible. Listed all the components below,
Akasa AK-ZEN-01-BK Rev 4 Zen Black Case
MSI P45 Platnium Intel P45 PCI-Express DDR2 Motherboard
Intel Core2 Quad Pro q6600 “energy efficient SLACR 95w edition” 2.40GHZ
Arctic Cooling Freezer 7 pro CPU Cooler
Corsair TX 750W ATX2.2 SLI Compliant PSU
OCZ 2GB (2X1GB) PC2-9200CS 1150 MHZ Reaper HPC Edition Dual Channel DDR2
Sapphire ATI Radeon HD 4780 X2 2048MB GDDR5 TV-OUT/Dual DVI/HDMI (PCI-Express)
Samsung Spinpoint F1 750GB Sata-II 32MB Cache OFM
Operating System: XP Pro SP3 32X
The system came with the standard case fan and also the cpu fan (with built in thermal paste). The machine is not overclocked.
I'm monitoring my temps using Speed Fan. When running on Idle the pc temps are as follows,
GPU: 84c
Temp1: 48c
Temp2: 29c
Temp3: -128c
HD0: 22C
Core 0: 66c
Core 1: 62c
Core 2: 54c
Core 3: 51c
Full load when running Crysis,
GPU: 90c
Temp1: 75c
Temp2: 30c
Temp3: 127c
HD0: 22c
Core 0: 82c
Core 1: 79c
Core 2: 66c
Core 3: 62c
1) Are these temps normal for full load?
2) Can the components handle these temps?
3) Is it possible to make the PC quieter without using water cooling? With Full load the PC sounds like a server.
4) Are my GPU temps okay?
Thanks in advance!
G
GPU: 84c
Temp1: 48c
Temp2: 29c
Temp3: -128c
HD0: 22C
Core 0: 66c
Core 1: 62c
Core 2: 54c
Core 3: 51c
GPU: 90c
Temp1: 75c
Temp2: 30c
Temp3: 127c
HD0: 22c
Core 0: 82c
Core 1: 79c
Core 2: 66c
Core 3: 62c
Thanks in advance!
G
