Im running the rig in my sig with Coolermaster 201-B standard case fans, last night SpeedFan indicated by system temp was around 52 load, cpu 44 load.
The system temp seems high to me so I was thinking about upgrading the rear or/and top (blowhole) fan.
Would this make much difference to the temps or is 52 load what I should be expecting?
If I should upgrade what would you recommend? The delta seems awesome but im concerned it will be far too noisy. How does it compare to the noise of the AC7 Pro at full speed? (3000rpm)
Thx
Thx
but far too noisey even with a good fan controler as i found
