Hello OcUK.
I've been looking at setting up a new computer and am kinda in doubt about what sort of cooling i should go.
First, specs of what i'm planning to buy:
i7 930 2.8 Ghz (to overclock to 4ghz)
Asus Rampage 2 Extreme
3x2gb Corsair Dominator DDR3
ATI Radeon 5870
Corsair Obsidian 800D
Corsair HX850W.
Now for the cooling, what sort of CPU should i go for to achieve good temps when overclocking?
These are the options i've been looking at:
http://www.overclockers.co.uk/showproduct.php?prodid=HS-076-TR (with 2 fans. Should they be intaking air aswell as the case fan close to the cpu or the other way around)
http://www.overclockers.co.uk/showproduct.php?prodid=WC-002-CS (same question as b4, should i add another fan and what direction should the air go?)
or at last, this?: http://www.overclockers.co.uk/showproduct.php?prodid=HS-068-TR&groupid=701&catid=57&subcat=
Along with the 3 fans i'll put in the top part of the case sucking hot air out of the case, will this get me some good temps or will i need to go watercooling? (by good temps i'm hoping below < 75º C)
Thanks in advance.
ATI Radeon 5870
Corsair HX850W.
Thanks in advance.
