Cooling and Ram Slots
3 Sep 2009
I am planning to build an I7 based rig and hopefully o/c it to 4.0 Ghz i plan on using a Gigabyte GA-X58A-UD3R Intel X58 MB with 3 sticks of ram
Looking at cooling options the Noctua NH-U12P SE2 Dual Fan Quiet CPU Cooler looks up to the task but i would like the option in the future to make use of all ram slots
Am i right in thinking that that noctua wil block some ram slots. If so is there another comaptable air cooler that will allow for the o/c and free all the ram slots
I have toyed with the idea of an H50 since it is quite compact and should free all the ram slots but 2 things put me off
1. It seems that there are more components likely to fail in an H50 and would require a complete replacement wheeras all that can fail in an air cooler is a fan, a lot cheaper to replace
2. Cooler reviews often give mixed results about the peformance of individual coolers but it seems from most i have seen that the h50 is not as good at cooling as the Noctua.
Also i accept that it may well ne that with all ram slots in use o/c will be restricted but i do a lot of heavy 3d graphics work and on some scenes RAM usage can be very heavy so though the high o/c is preferred i would like the option to increase my RAM if needed
I would avoid the Venomous
Going by a recent review in customPC, i would avoid this cooler. Apparently the older TRUE performs better...
This the thing about reviews no two are ever the same !! I was thinking about the Noctua DH-14 just to wind my son up, he has an i7 Goliath bought from here with a combination of birthday xmas money and saving.
I am lucky to get a pair of socks, I would love to see the look on his face as i unpacked a DH-14 !!
