Hi all!
i have some minor "issues" with my watercooled system and i thought maybe someone in a forum like this could help me out further.
the system is running fine and all but i think the temps are a bit to high for a custom watercooled system. first of all here is the spec list:
ryzen 1800x @3.8GHz*
crosshair VI hero*
32BG Gskill @3400MHz
2x GTX1080ti Founders edition (both watercooled)
corsair HX1000i
2x EK 360 PE radiator
D5 pump @ 3900 RPM
6x ek vardar fans @ 1200 RPM
*cooled by mainboard monoblock that cools CPU and VRM
after some gametime (2-4h) i noticed that both GPU's where around 62°C and also the CPU is around that temp.
that worries me a bit when you hear people like jayz two cents saying that this is way to high for a watercooled card...
what are you guys thinking? im using mayhems pastel white as a fluid. the fluid is fairly new so there should not be any build up. also recently i heard that glycol based coolants have a lower cooling capacity than distilled water. is that true?
do i need more surface area = more/thicker radiator? or should i switch back to distilled and dyed water?
if you need any more information just let me know (pictures, HWinfo screenshot, etc)
greetings and thanks a lot in advance
crosshair VI hero*
corsair HX1000i
D5 pump @ 3900 RPM
