Cooling Fans Needed?
17 Nov 2011
I've a HTPC in a Silverstone Milo ML03 case with these components,
CPU: AMD Phenom II X2 545 3.0GHz
Motherboard: Foxconn A7VMX-K
RAM: 4GB ASint Technology PC2-6400 DDR2
GPU: Asus AMD HD6450 1GB
HDD: Western Digital 500GB & Seagate Barracuda 2TB 7200RPM
PSU: High Power PUFP405S 405W
After watching a 1080p movie, I checked the CPU and GPU temperatures, the CPU max was 46°C and GPU was 65°C and the case feels warm as well. There's only a CPU fan in there and the GPU is passive cooling,
I see that the case can support 4 x 80mm fans, should I consider adding some fans or is the temperature fine?
