Cooling Fans
18 Mar 2006
Hi All.
Can someone recommend me two 120mm case fans and one 92mm side case panel fan. Would like them to be powered from the motherboard using the 3 pin if not from the power supply as I need decent air flow inside.
My case is a Thermaltake Aguila.
get the 2000rpm Sharkoon and put it down to 6.5 - 7v , just as quiet as the 1000rpm at that voltage, but gives you that extra headroom to bump them up when required.
