- 9 Jun 2008
I went and got a thermalright 120 ultra for my phenom II 550 dual core, as well as a couple of Enermax Magma Twister for an MSI 790fx-gd90, not knowing it wouldn't fit and you could only orientate it one way.
1: Because for a single GPU it needs to go in the slot closest which means the 'push' is about 5mm off the back of the card. The other slots only operate at 8X not 16X.
2: I got Corsair Dominator ram and with this cooler it doesnt fit in the right slots (dimm 1&2)
So I need to return this heatsink and fans.
Does anyone know a decent cooler for the AM3 slot that will fit and won't get in the way of corsair dominator ram?
Thanks!!
P.S
OCuk should stock the Enermax Magma Twister 120mm fans! They are just as quiet as the noctua vertex fans (got 3 of them on my case) yet they seem to blow more air.
Thanks!!
P.S
