Hi,
Have recently installed a MSI 390x and during gameplay the gpu temperatures are reaching 90+ and was wondering if anyone can advise on lowering these temps. Overclock has been removed so everything apart from custom fan curve is default.
Room temperature is approx 25-28 degrees.
All fans are 140mm except the rear which is 120mm. The fan at the side GPU has been removed as made no difference to the 390x.
thanks
thanks
