Cooling H440
10 Nov 2011
Telford
At the moment I currently have
H110 GT on my 5820K & H55 on my GTX 1080
Looking for something that has a bit more cooling performance & looks a bit nicer.
Really considering the EK Predator 360 & the prefilled GTX 180 block when its released.
Will the predator perform better than corsairs combined?
Obviously they will look better.
Will the pred 360 fit into my h440?
Front or top? I have no drive cages in atm.
I would estimate that going from to a predator will raise CPU temps but lower GPU temps whilst gaming. When just doing CPU tasks then temps will be a little bit lower. CPUs unfortunately suck at dissipating their heat.
Predator should fit into your h440 roof if you have clearance above your mobo heatsinks. If not then you can use the front as there is loads of space. I have a 60mm rad in push pull in the front of mine with room to spare.
