Cooling help?
5 Jan 2012
Caldicot, South-Wales
So I'm going to be upgrading to an Intel Core i5-3570K 3.40GHz (Ivybridge) up from a Sandybridge and I plan on doing some overclocking. Anyone know any good fans they can recommend?
Wasn't sure if this would go here or in the Hardware section, my bad.
Thanks guys, some good things for me to look through.
What about Liquid Cooling? Or isn't that not so great for OCing?
It is really good for OCing though the CLC's (closed loop coolers) with results equal or better than the D14/K2 are atleast £15 more.. See below:
YOUR BASKET
1 x Antec Kúhler H2O 920 Series 4 High Performance Liquid CPU Cooler (LGA1155 / LGA1156 / LGA1366 / 2011 / AM2 / AM2+ / AM2+ / AM3+) £84.98
1 x NZXT KRAKEN X40 AIO Water Cooling Unit - 140mm (Socket 775 / 1155 / 1156 / 1366 / 2011 / AMD AM2 / AM3 / AM3+ / FM1) £84.98
1 x Corsair Hydro H80i High Performance Liquid CPU Cooler (Socket LGA1155 / LGA1156 / LGA1366 / LGA2011/ AM2 / AM3 / FM1 / FM2) £76.98
Total : £258.35 (includes shipping : £9.50).
Yeah apparently the corsairs are loud, the went for performance over silence.
You may get a little noise from the pump as well, though you can RMA it if it's too loud.
I went for air cooling for the silence and cost benefits (its cheaper). :)
