- 22 Feb 2014
I have recently moved my home server cabinet from an open room to its own little (tiny) cupboard.
At present I have the door open to the cupboard to prevent it overheating.
However the room is in my office so i want to shut the door and eliminate some noise.
At present it has a single 120mm intake fan mounted to the bottom of the rack.
the rack contains
1 x modem
1 x router
1 x 24 port gigabit Hp switch
1 x homebuilt NAS, (8 HDDs)
1 x APC UPS
temps are fine at present, however as I said the door is open, further to that I havent reattached the front door of the cab yet either.
The cab is made of metal but has had a wooden veneered top put on it.
I am happy to cut holes in the cabinet for additional cooling to be installed.
The only place I can really vent the warm air to is the room I am stood in taking the picture, I assume via some kind of vent above the door, which is also fine.
I'm looking for a bit of advice on exact kit to buy and best way to tackle this.
I'll probably need some kind of hole to allow cooler air to be drawn in to the cupboard, then i assume best way to vent would be a vent directly from top of cabinet through some ducting and out of the cupboard ?
the rack contains
1 x modem
1 x router
1 x APC UPS
