Hi all,
My rig has been making quite a racket for some time and I am looking to upgrade the fans in my Antec 1200 case. There are several fans in my case:
3x120mm intake fans in the front. The bottom two have hard drives behind them. The third has a small SSD behind it which doesn’t really block the fan as it is so small (unlike multiple hard drives behind the two fans below)
2x120mm exhaust fans in the rear
1x200mm exhaust fan at the top
2xNF-P12 intake/exhaust fans on the heatsink
So 8 fans in total.
I presume that I don’t need to replace the Noctua NF-P12 fans? These are supposedly good and quiet. The others are quite loud though.
What would you suggest?
I don’t have a firm understanding of static vs. air flow. If I were to hazard a guess, I would say that rear fans and top fan should “push" air out while the front 3 fans should “pull” air in. Does Airflow at the rear and top and static in the front seem sensible?
I am keen to have my PC quiet as possible.
Any thoughts would be very appreciated
RS
So 8 fans in total.
RS
